How far do the Lower Lift Arms lift from the ground up?? Massey 135
Willy-N
08-29-2002 09:06:16
How far do the Lower Lift Arms lift on the Massey 135? If they are at rest lowest posision to the Max height. I have the type that have a latch at the ends you can release to lower the tip to hook up something then lock it again. They also have another set of pins for the stableizer bars just back from the 3-point ones. Mark H.
Willy-N Solved the problem!!
08-30-2002 14:24:51
 Re: How far do the Lower Lift Arms lift from the ground up?? Massey 135 in reply to Willy-N, 08-29-2002 09:06:16
I found out why the blade did not lift as far as my Ferguson did. The upper 3-point bar was to long! I bought another one 2 inches shorter and the lift went from 6 inches to around 18 inches in lift. Now I won't have a problem dumping snow out from under the blade this winter! Mark H.
