How much disc??
Yankee in Tn.
08-25-2002 05:55:16
I have a 1964 MF35Deluxe gas.My question is how big of a drag disc will it pull with out working it to hard?I have some yard and some pasture i would like to smooth out and replant.Also cut some waterways to help eliminate erosion in the pasture. Thanx in advance,Yankee
Boss Hog
08-29-2002 10:45:09
 Re: How much disc?? in reply to Yankee in Tn., 08-25-2002 05:55:16
You can probably pull a 10' disk on hard ground. But you may have to carry it quite a bit on softer ground. Depends a lot on how heavy the disk is.
As the other guy mentioned, a 6' or 7' model mounted disk is ideal. But the last one I saw go at an auction went for $500.
gy3020
08-25-2002 15:49:58
I don't think I would want to pull over a 6' disk behind it. It could pull more in certain conditions but for safe all around plowing a 6' would work pretty good and plow your tracks out.
That is what I am looking for for my 135 MF but I want a 3pt version so I can take it and do some garden plowing and be able to haul it on my 16' trailer. Hope this helps.
Gary
