Temp guage wire
Ken
08-23-2002 15:16:39
My Temperature gage wire is broken; it appears to be a solid wire, wrapped by a coil wire. Both are broken and the temp gage is inoperative. How do I repair the wire, or do I have to replace it?
Thanks, Ken
Alberta Mike
08-25-2002 19:23:44
 Re: Temp guage wire in reply to Ken, 08-23-2002 15:16:39
When you go to buy a new gauge, try to find one without the dual temperature readings on it, like Celsius and Farenheit both. All the old tractors had the F readings only and I find the new gauges a bit cluttered looking if both scales are on it, plus there's always too much color too, blues and reds, etc. which somehow don't look right. Try to find one with as close to the proper length as you need, sometimes you end up having to spool 4-5 feet of tubing somewhere.
smokey1
08-23-2002 16:30:17
The unit is mechanical and you will need to replace it. Most auto shops carry cheap mechanical temp gauges which should fit.
