HELP on TO35 Electrical
Rob Pearce
08-22-2002 15:10:25
As usual I know enough to be in trouble!! I need some help. I recently got a TO35(it came with the place I bought). It is very sick, but I got it running. I replaced the starter, generator, regulator, selenoid, and put in a tune up kit, and it is running much better. It was wired as a 6 volt negative ground which is the way I replaced everything. My question is the manual I have says it should be wired as a positive ground. It seems to work fine,the only problem is it charges at 20 amps at full trottle and stays there, the regulator never cuts out the charging. Have I messed something up! Also, which way should the hand trottle be moved to increase rpm, right now I have to move it from right to left (push) the manual says it should be move from left to right (pulled toward driver). This poor old tractor has had lots of "modifications" to it. Any help will be appreciated
Allan
08-23-2002 21:52:56
 Re: HELP on TO35 Electrical in reply to Rob Pearce, 08-22-2002 15:10:25
The only thing that may be unhappy about the ground being reversed is the voltage regulator. They are usually marked for pos or neg ground. That may be why the overcharge.
Rob
08-26-2002 07:16:42
 Re: Re: HELP on TO35 Electrical in reply to Allan, 08-23-2002 21:52:56
Hi Allan:
The other thing I forgot to mention is if I change the polarity to a postitive ground then my ammeter reads in the negative. I had another person tell me to change the wiring (switch wires) on the ammeter and everything will be ok. Is that correct?
