MH44GS Running bad
Mark S
08-21-2002 07:12:25
I recently purchased this tractor and last night I got on it and it started right up. With a 8ft backblade I was able to Pop up a couple small tree stumps. Happy with how that worked I attempted a larger stump, but it wouldn't budge and the tractor began to run rough. Thinking maybe it was sedement in the gas, I cleaned the bowl,fuel line, and sprayed some carb cleaner in the carb and added 5 gallons fresh gas, No luck.
I did notice a new oil leak at the front of exhaust manifold. And now it won't start.Stuck valve?blown gasket?? Any ideas??? Thank You Mark
Mark S
08-22-2002 05:38:41
 Re: MH44GS Running bad in reply to Mark S, 08-21-2002 07:12:25
Worked on it some more, charged the battery and cleaned the plugs (Wet and black), adjusted carb, checked/cleaned the points and wires. Started up OK but after about a minute it would sputter, shake, and backfired. Maybe electrical? going to change cap and rotor? Mark MH (44GR 15540)
