TO35 hydralic problem
Jason
08-16-2002 07:05:48
I have a problem with the 3pt. on my TO35 not wanting to raise. It works fine for awhile then won't raise. I am not sure if after the oil gets hot it is bypassing the seals or if it is something else. Any help would be greatly appreciated.
d3 Mike
08-24-2002 23:44:49
 Re: TO35 hydralic problem in reply to Jason, 08-16-2002 07:05:48
Some TO35's have a filter behind left inspection plate. The filter is a fine mesh and should be cleaned. While the plate is off, run the tractor and look around for oil spraying around,if so, find the leak before you pull the top. also check for turbulance at the rear of the pump on the right side,if so, the relief valve is blown. Good luck, Mike
Paul
08-17-2002 17:11:22
It could be the oil is getting too thin when it warms up. What grade oil are you using? Check out Big Deans site & email your question to him. If he cant help, no-one can. good luck
Gordon-(TN)
08-17-2002 00:25:34
Jason
if the lift goes down fast when the motor stops it is most likley the ring on lift piston worn badley,the cylinder wears also, it is under the plate the seat is mounted on.
hope this helps.
Gordon-(TN)
