Throtle not staying open
Mickey Cook
08-12-2002 17:55:04
Just restored a TO35. Everyting works great except the throtle want stay in place when you open it up. I've tried to adjust the spring with no success. Help me if you can.
Doug
08-12-2002 19:19:41
 Re: Throtle not staying open in reply to Mickey Cook, 08-12-2002 17:55:04
I had the same problem on my MF-65. Turns out there are two cork washers which regulate the tension on the throttle lever. They are right under the control panel on the MF-65. When they dried up, they no longer caused the friction needed to keep the throttle lever in place, so the throttle would not stay open. I don't know if the TO35 has the same set-up, but you might want to check.
Mickey Cook
08-15-2002 03:52:51
 Re: Re: Throtle not staying open in reply to Doug, 08-12-2002 19:19:41
Doug the cork worked great. Thanks for your help.
