MF 245 Lower Link Shaft is loose
Problem?
Dave
08-11-2002 20:56:17
I just bought a used MF245 (Standard) with a 3-152 Perkins. After cleaning it up a little I noticed that one of the Lower Link Shafts (1867851M3) is loose. My parts book shows that it inserts into the Rear Axle Housing but fails to show if the housing is threaded or if the shaft screws into something inside. I was wondering (1) I can shake and rotate the shaft by hand the other side is very tight, is this a problem? (2) Anyone know what the shaft screws into??
Thanks
H.T.Hertz
08-12-2002 02:44:14
 Re: MF 245 Lower Link Shaft is loose - Problem? in reply to Dave, 08-11-2002 20:56:17
It has a nut on the inside. :-(
