Increase HP on gas MF 65
j mount
08-08-2002 03:55:12
WHAT IS THE BEST METHOD TO INCREASE THE HORSEPOWER ON A MF 65 GAS ENGINE?? I WOULD LIKE TO INCREASE IT ABOUT 10 HP OR MORE. YOU CAN E-M ME AT [email protected]
Doug
08-12-2002 19:27:29
 Re: increase HP on gas MF 65 in reply to j mount, 08-08-2002 03:55:12
Installing an over-bore kit will give you at least 10 more HP. This involves having the cylinders bored out by a machine shop, then installing new, larger sleeves, pistons and rings, etc. I can't even guess what it would cost, but it is probably cheaper than buying a bigger tractor.
j-mount
08-15-2002 03:48:16
 Re: Re: increase HP on gas MF 65 in reply to Doug, 08-12-2002 19:27:29
thanks DOUG. I WAS CHECKING THE SPECK'S ON THE MF 65 THERE WAS A HIGH ALTITUDE MODEL THAT HAD AN 8 TO 1 COMPRESSION RATIO AND THE L-P MODEL HAD A 8.75 TO 1 RATIO. THE STANDARD GAS HAD A 7 TO 1 COMPRESSION RATIO. I DONT KNOW IF THE DIFFERANCE WAS THE PISTONS, OR IN THE HEAD ITSELF. MABY SOMEONE MIGHT BE ABLE TO LET ME KNOW.AND WHERE I MIGHT FIND THE PART'S. THANKS.
