TACH/HOUR METER HOOKUP WITH ALTERNATOR CONVERSION
JERRY G MCGLAUH
08-05-2002 22:26:27
JUST READ THE ARTICLE ON CONVERTING TO AN ALTERNATOR. MY QUESTION IS HOW DO YOU GET THE TACH/HOUR METER METER TO WORK AFTER THIS CONVERSION? MY MF 135 DOESN'T HAVE THE RIGHT GENERATOR ON IT ANYWAY SO THIS IS PROBABLY CHEAPER THAN GETTING THE CORRECT GENERATOR. MY CONCERN IS THE HOUR METER FOR MAINTAINANCE PURPOSES,AND WOULD LIKE TO HAVE THE TACH WORKING TOO. ANY HELP WOULD BE APPRECIATED,AND THANKS IN ADVANCE.
Marcel Gosselin
08-12-2002 09:11:56
 Re: TACH/HOUR METER HOOKUP WITH ALTERNATOR CONVERSION in reply to JERRY G MCGLAUHLIN, 08-05-2002 22:26:27
Massey made a factory alternator with tach hook up on the back for the later years of the 100 series. I replaced mine for $100 canadian last fall. Check early posts, lots of discussion about this topic. If you have a diesel engine I believe you can get a gear setup from a 200 series engine to work.
JERRY MCGLAUGHLIN
08-12-2002 17:42:32
 Re: Re: TACH/HOUR METER HOOKUP WITH ALTERNATOR CONVERSION in reply to Marcel Gosselin, 08-12-2002 09:11:56
MARCEL, THANKS FOR THE EXCELLENT INFORMATION ABOUT THE ALTERNATOR. I AM GOING TO THE DEALER TOMMORROW SO I WILL ASK ABOUT THIS. MY ENGINE IS A 4cy CONTINENTAL, SO I GUESS THE DIESEL IDEA WON'T WORK, BUT I WILL ASK AROUND.
jiml
08-10-2002 09:03:16
I have a Super 90 diesel and plan to replace the generator with an alternator. I am thinking of dismantling the alt, center drilling the armature shaft, threading to accept the drive gear and fabricating some type of mount for the tach drive housing. I plan to use the generator pulley on the alt to keep rpm the same. Has anyone done this?
garvas
08-07-2002 10:49:18
My MF35 hour meter quit working so I just broke down and bought a regular hour meter $32.00 at an auto supply. Mounted it under the hood and wired it to the ignition switch to the coil wire. Works great. Remember this will monitor the hours on the motor with no regard to speed.
JERRY MCGLAUGHLIN
08-10-2002 00:36:12
 Re: Re: TACH/HOUR METER HOOKUP WITH ALTERNATOR CONVERSION in reply to garvas, 08-07-2002 10:49:18
GARVAS, THANKS FOR THE IDEA, THAT WAS IN THE BACK OF MY MIND, TO DO IF I DON'T GO THE TRADITIONALY WAY.I APPRECIATE THE HELP.
