Steering Gear Info
Wes Johnson
08-05-2002 19:06:02
Does anyone know where I could get a Steering worm gear and shaft assembly for a MH 44-6 Adjustable Hi-Arch wide front part # 761-183-M91.
M-H Guy
08-09-2002 11:37:02
 Re: Steering Gear Info in reply to Wes Johnson, 08-05-2002 19:06:02
Wes,
Are you sure you need the worm and shaft? Unless
bad bearings have worn the ends on the worm, the
sector gear is usually showing wear in the four
center teeth. A decent backlash, new bearings,
new bushing, should vastly improve your steering
box. Most M-H wide fronts have right hand thread
on the worm, difficult to find, as the NFE's were
left hand thread(turn steering wheel right, the 44 front wheels would turn left). Good luck.
