HELP! M F 3 POINT
d3 Mike
08-05-2002 01:02:40
I hope life is treating you well. I have an early 1964 M F 205 industrial with an I-R trans. The 3 point controls, draft and position, seem to be the same as a TO 35 or 50. When I engage the 3 point, the arms rise slowly about an inch, then settle back down. This happens only on the first try, after that nothing happens.I put permatran 3 in it, and test it in neutral with the forward pedal pressed. Is their a filter in the system? Can I change it without removing the top of the trans? Any other suggestions are greatly appreciated, as always! Thank You , Mike
rod
08-05-2002 13:55:09
 Re: HELP! M F 3 POINT in reply to d3 Mike, 08-05-2002 01:02:40
I have a parts book and yes there is a filter send my your email address I would send you a scanned pic.
regards
rod
d3 Mike, Thanks Rod
08-05-2002 19:49:26
 Re: Re: HELP! M F 3 POINT in reply to rod, 08-05-2002 13:55:09
High Rod , any info on the MF 3 point would be appreciated. Thanks, Mike [email protected]
