MF 1150 Parking Gear
Ken- Ky.
07-30-2002 20:34:32
A friend of mine was driving my MF 1150 down a hill pulling two wagons loaded with 6 round bales of hay on each wagon. He went through a gate and stopped, headed downward, on a hill and placed the tractor in park and released the brakes. This allowed the loaded weight to shift hard against the parking gear. When he tried to pull the gear shift out of Park position he pulled so hard that it slipped the linkage just enough to allow the gear shift handle to be place in 1st gear, but the tractor never came out of park. He pulled foward about 5-6 feet while the tractor was in park and the parking gear was making a lot of knocking noise. I got the linkage fixed but the parking gear appears to be only engaging only about half-way, it will slip out of park if parked on a hill. Does anyone know what I should do next to fix the parking gear?
Charlie
10-04-2002 18:43:05
 Re: MF 1150 Parking Gear in reply to Ken- Ky., 07-30-2002 20:34:32
If you take the panel off you will need to drain some of the trans oil out. At least 1100 is this way.
Eric Nulsen
08-07-2002 13:21:36
If this is like my 1100, then he has probably broken the parking brake pawl(?) in the transmission or bent the linkage. On the 1100 it is on the left side of the transmission. I believe you can access it through a panel on the side of the case. Hope this helps
Eric N.
