Method of restoring tyre rubber
Damon
07-29-2002 21:47:40
The rear tyres on my tractor have a bit of cracking of the side walls. I was wondering if there is anything that can be done to perserve or repair the rubber. Tread is still good so I don't want to have to go to the expense of buying replacements.
Thanks,
Damon
keith
09-06-2003 18:15:46
 Re: method of restoring tyre rubber in reply to Damon, 07-29-2002 21:47:40
im 14 and have been just covering my tires with plastic and park on boards and also cover the intire thing with a tarp or park in garage and that is how me and neighbors do it and it stays fine so good luck
Gary
08-01-2002 04:55:40
you know what,my father used this stuff called ru-glide sold to tire shops they use it around the bead for installation of tires! it must have a silicone base to it! check the tire shops maybe they can fill you in!! good luck.
Damon
08-01-2002 15:03:11
 Re: Re: method of restoring tyre rubber in reply to Gary, 08-01-2002 04:55:40
Thanks Gary, I will look into it.
Regards,
Damon
