Governor
garvas
07-22-2002 07:30:20
Read the book on adjusting governor for MF35 and wondering how bad I can screw it up when I try to adjust it.
Jim/Mississippi
07-22-2002 18:25:04
 Re: governor in reply to garvas, 07-22-2002 07:30:20
How is the governor 's operations now.
garvas
07-23-2002 03:45:19
 Re: Re: governor in reply to Jim/Mississippi, 07-22-2002 18:25:04
When mowing the engine RPM does not seen to respond to differnt loads on the mower. It may bog down and die if I don't move the throttle higher. How should it resond?
Jim/Mississippi
07-23-2002 21:16:59
 Re: Re: Re: governor in reply to garvas, 07-23-2002 03:45:19
I see your point. I beleive the
governor should try and maintain
the RPM you had pulled the throttle
lever to.
The vertical rod (which links your
throttle control rod down to your
governor lever), is this rod adjusted
down far enough so that it touches
your governor lever?
Even with the throttle
set to the lowest RPM setting?
From what I've read, this is one
of the most mandatory requirements
in achieving proper governor operation.
Jim
