Rear rims for a 101 Senior
Kevin
07-21-2002 21:03:18
I'm getting ready to buy a Massey Harris 101 Senior the only problem that I have found with it is the rear rims are rusted through in places right at the bead and around the valve stem. The tires have fluid in them I know that is what caused it. I'm just wondering how hard it is to find rims that will fit. Thinks for any info.
David B
07-22-2002 10:58:02
 Re: Rear rims for a 101 Senior in reply to Kevin, 07-21-2002 21:03:18
nine bolt wheels can be found, they were made to use as dual on later tractors. Finding them the right width taks a lot of looking. Sometimes if only the valve hole is rotted out it can be cut out and a piece from an old rim welded in. If nothing else, save your center and maybe you can get a naked rim and put your center in it.. If you buy one that has been for duals you may want to move the center over in the rim anyway.
LH
07-22-2002 08:18:00
My Super 101 Twin Power is also in need of new rear rims in the next few years. From what I see they look to be standard 9 bolt pattern pressed steel 38 inch rims which should be easy to find.
