44-6 governor cycling. Please Help,So I don't have toJunk it.
Tony Ceder
07-15-2002 17:36:40
I bought a Massey Harris 44-6 and just got it running. The governor cycles real bad. When you idle it down it runs smoother. The intake can suck the glove off your hand. If you cover part of the intake it runs a little better. What might be causing this? Please help! Thanks Tony Ceder
David Berger
08-11-2002 08:34:26
 Re: 44-6 governor cycling. Please Help,So I don't have toJunk it. in reply to Tony Ceder, 07-15-2002 17:36:40
If it comes down to junking dont cause id but it. :)
wayne
07-16-2002 18:58:14
I had this happen,and it was the manifold gasket leaking,you can test this by idling the engine slow,then take a spray can of brake clean and spray around the gaskets including the carb mount gasket,when you hit a leak the engine will speed up or smooth out.
Wayne
gatractorman
07-16-2002 04:07:08
Sounds like just a carb. adjustment needed, the gov. is just regulating the butterfly to keep it running, and also when you cover part of the intake it runs better, what your doing is cutting down the amount of air that gets in, whats happening is the air-fuel mix is wrong, not enough fuel for all the air goin in. May take a carb. rebuild to get it right since it sounds like it has been sitting.
