MF 135 Lift Problem
Jim M
02-16-1999 09:57:49
The 3 point lift on my 135 responds slowly, going up or down. I checked pump pressure and it's on the money.I checked and cleaned the filter (it wasn't dirty), and synchronized the control valve.Now; this tractor is plumbed with remote hydrolics. The trasfer plate on the lift cover has been replaced with one that has what I call a switch or control lever(about 2" long). This lever has to be exactly centered or up or lift doesn't work at all.I removed the hoses and control valve, (not the same one as above), and plugged the holes. The only # on the transfer plate is TS 300. Could there be some problem with the return oil. Thanks for any help.
Chris Gilliland
01-17-2000 17:25:58
 What is the name of the part that replaces the transfer cap... in reply to
