Alternator on MF 1100
Eric
01-17-2000 06:37:57
I have replaced the alternator on my MF 1100 with an alternator with an internal regulator. I ran the hot lead from the oil pressure switch to the field terminal on the alternator. I hooked up the power lead from the alternator to the battery circuit where it was originally hooked up. The problem is that the alternator will not charge until I rev the engine to about 18-1900 rpm. Then it charges just fine, even at idle. Any ideas would be appreciated. Thank You
Eric N.
Louis
02-19-2000 21:08:07
 Re: alternator on MF 1100 in reply to Eric, 01-17-2000 06:37:57
Eric,
The alt. must be "excited" before it will charge. This is not happening till you spin the alt. pully to about 1350rpm.. You may need a smaller pully on the alt.
ted
01-20-2000 06:40:05
Our 270 does that, but we only have to rev up a little.
When I replaced the alt. on our 1150 I got a new keyswitch from dealer, off-on-start. I think it was from the 1xx series? Anyhow it looks the same and fits good. I hooked the sensor wire to the origional output wires, and the hot was from the key. I didn't trust our oil pressure switch. Be sure to unhook the regulator.
We always had regulator problems and this finally fixed them.
Another reason I put a new keyswitch was so I could have the radio and other stuff on a switch.
Tyler(WA)
01-18-2000 13:58:31
Check your e-mail.
Richard
01-17-2000 20:20:56
Go to parts and supplies on ths site.
Go to the one marked Genesee and look the 6 to 12 volt info and go to the bottom of the page it will tell you were the #1 and #2 terminals hook up at. The pulley size may make a difference also .Are you using the delco alt.?
Eric
01-18-2000 06:17:17
 Re: Re: alternator on MF 1100 in reply to Richard, 01-17-2000 20:20:56
I will check and see if my alternator is a 10-SI and proceed. Thanks for the help.
Eric N.
