Fuel Filters
Wayne in TN.
07-11-2002 19:38:54
I have a '66 mf135 diesel.It has a sediment bowl that I have cleaned and primary and secondary filter that I have not changed and would like to do so.Are there any tricks to this as I know air is an issue. Thanks in advance for any pointers!
smokey
07-12-2002 04:18:31
 Re: Fuel Filters in reply to Wayne in TN., 07-11-2002 19:38:54
No tricks but.... bleed from fuel tank to injectors, Use lift pump on bowl to hand pump fuel through filters. This may be enough but if not then you may need to slacken injector pipes one at a time to bleed to the injector. Be aware there is a cone mesh filter above the fuel cutoff tap in fuel tank and a mesh filter above the sediment bowl. see big Dean Austin's site for further details.
