Massey harris pony
john wilson
01-17-2000 04:58:03
I am looking at a massey harris pony to restore and use as a cultivating tractor. I currently own an 8N and a Massey 231. The Pony that I am looking at has been largely unused and is sitting in a barn for the last 10 years. It appears complete. Has cultivators and single furrow plow. It has a draw bar. No hydraulics. One back tire looks new one terrible. Are tires easy to get for this machine. Would it be a good purchase at $500. What should I look for. It is unlikelly the engine turns right now. I would move it from the -10C barn and move it to our shop before working on it. If it turns out to be of no use for cultivating, how hard is it to equip with a belly mower and is this worth while. What about turf tires?
Thanks John
Ron Roe
02-01-2001 20:32:53
 Re: massey harris pony in reply to john wilson, 01-17-2000 04:58:03
My Dad is restoring a Pony and is having trouble getting any oil pressure. He has replaced the gears that pump the oil to the guage and the other parts that effect the pressure. When he stopped up the relief or overflow the pressure increased slightly. He is at wits end does anyone have any helpful hints? thanks Ron
Ben
04-13-2001 19:38:19
 Re: Re: massey harris pony in reply to Ron Roe, 02-01-2001 20:32:53
The timing on the guage could be off, try replacing the guage or resetting it. Also check all your seals. Sometimes some oil leakes out of the bolts that attach the manifold (on the right side)to the engin block. Also note the oil pressure is only suppose to be 20 to 30 pounds. Also check valves. Hope this helps! Bye.
Ken
01-17-2000 22:27:51
Comments: Tires are easy to get. They are a common size. I have cultivators that I use for cultivating-the clearance is good but that tractor has hydraulics. It is also good for making rows with rear rowmakers. I have one tractor with a belly mower(home made) and have seen another. You need a pto for belly mower.
john wilson
01-18-2000 05:31:02
 Re: Re: massey harris pony in reply to Ken, 01-17-2000 22:27:51
Thanks for the comments Ken. I think I will buy the tractor. It is frozen in the dirt of the barn now but next thaw I will bring it home. The tractor has a pto but no hydraulics. Is this a problem for a belly mower. I haven't checked out how you lift the cultivators on the tractor. I presume with a handle. Would the belly mower be raised in a similar manner? Is it possible to take the hydraulics from a wrecked pony and retrofit them onto a tractor that has no hydraulics?
