Mh 44 steering parts
jeff
07-10-2002 18:43:03
hi ineed steering sector shaft or complete steering gear box for massey harris 44 wide front end. not sure of year as serial # tag is gone.
i dont know of another way to tell year.any help would be helpful thank you
David B
07-11-2002 16:15:37
 Re: mh 44 steering parts in reply to jeff, 07-10-2002 18:43:03
Is the steering gesr box on the wide fronts the same as rowcrops? Is it a saginaw unit? You can find the tractor model and serial number stamped on the trans-rear end gear case along the top left side between the rear end top cover and the transmision top cover
jeff
07-12-2002 12:25:31
 Re: Re: mh 44 steering parts in reply to David B, 07-11-2002 16:15:37
thank you for the info to find numbers.i am not sure about rowcrops?
