Steering worm gear seal
David B
07-09-2002 13:38:35
Need to find where I can buy a seal for the steering shaft in my 44-6. 7/8 x 1 28/32 x 5/8 M H part# 760-908M1
Bruce Colbourne
07-16-2002 20:44:27
 Re: steering worm gear seal in reply to David B, 07-09-2002 13:38:35
I get my seals from a local bearing supplier that I get my bearings from.What I did with one seal was I put in two seals.The replacement seals were half as thick as the original so this worked out perfect.Your local bearing supplier should be able to get you what you need.
Michael
07-11-2002 11:33:11
David,
The numbers are all but useless after several
decades. If you look in the yellow pages for a bearing/bushing supply, call a few. By taking
the steering box and worm shaft in, they will size it, pull one from the shelf, or order one.
Good luck on the 44-6.
David B
07-11-2002 16:19:36
 Re: Re: steering worm gear seal in reply to Michael, 07-11-2002 11:33:11
Thanks for the reply. I can get a seal from a automotive parts store that has the correct inside and outside diameters but not as thick as the original but looks like that is the only thing aviable. Thanks David B
