TO-35 Steering Free-Play
RHS
07-09-2002 11:20:03
WOW � what a site! I discovered this site a couple of weeks ago while looking for parts and have learned more about my tractor than I would have ever believed possible. This site led me to discover that my �old Massey Ferguson that looks like an old gray Ford� was actually a 1955 Ferguson TO-35 Deluxe. I�ve a lot more respect for her now. With my new service manual, plus the info in the posts on this site, I can give her the TLC she deserves.
Now for my problem. I�ve excessive play in the steering box. Free-play of about 4- 6 inches in the steering wheel without the pitman arms moving indicates the play is in the steering gears. The I&T Shop Service manual describes how to adjust the worm gear preload (by adding or removing shims) and sector backlash (via the adjustment screws) to achieve the desired 3-5 lbs. force to turn the steering wheel. But, there is no mention of what/how to adjust to remove free-play.
Question � can the free-play be adjusted out or are the gears or bearings worn out? If it can be adjusted, is the adjustment to the worm gear or sector shafts?
I�d like to find out all I can, and hopefully how to fix the problem without having to remove the steering box or replace gears. Any help is appreciated.
Thanks,
RHS
