MF 10 engine problem
Ken
07-08-2002 16:47:32
Hi all,
I was wondering if someone could help me out with an engine problem. I popped the clutch while mowing the lawn and hurt a load clanking noise, then the engine died. When I go to start it now, it makes the same noise and wouldn't start. When I turn the main pulley, it only moves 3/4 of the way around. I dont think it's the crankshaft because I took out the sparkplug and the value moves. The main pulley also moves on both sides of the engine too. Any ideas on what could be wrong?
Many thanks in advance!
Ken
ken
07-09-2002 16:38:47
 Re: MF 10 engine problem in reply to Ken, 07-08-2002 16:47:32
I did some more investigation and found out that the connecting rod is broke. The cylinder bore looks ok. Does anyone know where I can get a new one or what the model number for the Briggs and Stratton engine?
Thanks!
ed marshall
07-17-2002 07:38:31
 Re: Re: MF 10 engine problem in reply to ken, 07-09-2002 16:38:47
i have a lawn tracotr mf10 b& s eng do you have a pix for mower deck parts or list of. drive pulley to deck turns 90 degrees. need age of lawn tractor, guess 1957? thanks.
rob
07-09-2002 18:12:42
Ken
It came from the factory with a tecumseh hh100. you might need your spec. number when calling for parts. If it is a briggs I am no help!
ken
07-09-2002 18:17:22
 Re: Re: Re: MF 10 engine problem in reply to rob, 07-09-2002 18:12:42
Ah, Thanks Rob. Your right. I foolishly listened to someone who said Tecumseh didn't make engines that long ago. I'm having a problem finding the connecting rod for it though.
Thanks again
