MF135 slow hydralics
Deane
07-03-2002 11:09:46
I have a 1968 MF135. When I first start the engine it takes several minutes before the 3 pt will lift(I operate the position and draft levers). After it lifts the first time it only hesitates a second before lifting. I engaged the pto and it turns right away. Any help appreciated
Deane
07-05-2002 12:28:04
 Re: MF135 slow hydralics in reply to Deane, 07-03-2002 11:09:46
Hydralic filter was 3/4 disintegrated. Flushed with diesel fuel,new filter and new hydralic oil. Seems to work OK right now.
David
07-03-2002 20:22:43
A choked hydraulic oil filter is the first thing I'd suspect. Its located inside the transmission case but can be changed by taking off one of the side plates. I can't recall which one but I think it may be the one that the PTO lever is on. Ideally you should drain the oil before taking it off but you can do it without taking the oil our if you put the wheel up on a ramp to run the oil to the other side.
Brad
07-05-2002 08:50:39
 Re: Re: MF135 slow hydralics in reply to David, 07-03-2002 20:22:43
Our happens ONLY when the tractor is cold when started, you must warm the engine for about a minute to 2, push throttle higher til you can move the hydralics, otherwise, go with the other post.
