MF-150 hydraulic oil
Mike Taulbee
06-29-2002 12:27:48
I have a MF-150 and I need to know how to change the hydraulic oil and how much and what kind to put back in I have a IT shop manual but it does cover this I sure would apperciate some help Thanks Mike
Ray, Md.
07-01-2002 08:26:45
 Re: MF-150 hydraulic oil in reply to Mike Taulbee, 06-29-2002 12:27:48
Mike,
I have a MF-150, uses 7.5 Gallons of hydraulic fluid, two drain plugs. There are 3 drain plugs on the underside of tractor the first (front to back) is the crankcase engine drain plug. The next two are the ones you want to drain from. If the fluid has not been changed for a while or it looks like water might have gotten in there. I would go to Wal-Mart and buy their trans-hydra fluid and use it as a flush, start it up and let it run for a while and drain it out. Then go to your MF dealer and buy the MF fluid they carry. You can get a 5 gallon bucket and also a 2.5 jug. I would buy two five gallon buckets. It is little cheaper per gallon and you only have to buy a 5 gallon one on the next change. Cost around here for MF fluid is $35 for 5 gallons. Level stick is on the right, while setting on tractor.
