Cutch stuck MF 65
Roger Cattermol
06-29-2002 11:52:35
stupidly drove tractor into pond water in bell housing stood for a few days now clutch will not dis-engage. can drive in low range by crashing gears gently , tried towing no help.
Any suggestions before i dismantle.
bob
06-30-2002 11:47:59
 Re: cutch stuck MF 65 in reply to Roger Cattermole, 06-29-2002 11:52:35
any inspection plate on the back of the bellhousing? Sometimes you can pull the inspection plate and pour boiling hot water over the clutch & pressure plaate & break it free
Roger
07-01-2002 14:52:06
 Re: Re: cutch stuck MF 65 in reply to bob, 06-30-2002 11:47:59
Hi Big Dean Shawnee + Bob Tried your plan ploughed decent few furrows but alas clutch still stuck.
On the tractor forum (Bob) boiling water was suggested. Took the starter motor off and poured few litres in but appeared not to help engine stalled with footbrake. Then I thought of using washing up liquid , suirted some around flywheel seemed highly unlikely any would reach clutch plates since access very restricted. Took tractor down a hill at speed then throttled back and blow me if the clutch disengaged. Miracle. thanks for all your help
Regards Roger
