Deere Mower Conversion
Rick Magee
06-27-2002 19:42:09
I have a Massy Harris Pony and I am away from the tractor. I am able to purchase a Deere 5' belly mower from a 400. My questions are (1) has anyone done the attachment (2) Will the drive shaft convert to the rear position (3) Does my PTO turn counterclockwise (4) Can I pully to drive the blades at a suitble speed (5) Does my tractor have the power with a newly rebuilt oversized motor
Yankee
06-28-2002 06:44:29
 Re: Deere Mower Conversion in reply to Rick Magee, 06-27-2002 19:42:09
I tried to do the same thing with a Woods on a MF35.The main problem was that most if not all the belly ptos turn much faster,about 2150rpm.Check the tractor your mower came from.Not to be outsmarted by a machine,I mounted a 16hp.Brigs v-twin on a frame and belt drive to the mower gear box.If you have a vertical shaft engine you could eliminate the gear box,but watch your engine rpm.TSC among others sells a pull behind unit similar to what I built,if you want to get an idea what I'm talking about.You can e-mail me with any questions you may have.
