MF 85 gas --- Gas tank gets hot!
Jeff
06-27-2002 11:11:41
I was cutting hay yesterday with my MF85. I stopped to check the fuel level & there was a lot of pressure in the tank. In fact there was a constant amount of low pressure after I opened the gas cap. Just by setting the cap over the hole, I could hear the pressure. I felt the tank & it was quite warm. The engine was running around 175 degrees ( the fuel tank sits directly over the engine ). I've never noticed this before. I anyone familiar with this, and should I be concerned at all?
Thanks
Jeff
Jeff
07-02-2002 07:01:19
 Re: MF 85 gas --- Gas tank gets hot! in reply to Jeff, 06-27-2002 11:11:41
I had someone contact me via email, and they asked if there was a heat shield over the exhaust manifold, which there wasn't. I bent up some old sheet metal & put it on, and "presto" no more pressure in the tank.
dieseltruk
06-28-2002 16:00:56
If it is building that much pressure, the cap and/or tank vent may be restricted.
