Correct gears for M.F. work.
David Layne
06-26-2002 16:42:10
I have a Massey Fergerson 35 to which I have attached a "Big Bee" 72 inch finishing mower. The mower manual calls for 540 r.p.m.'s what is the best gears to use on the Massey Ferguson to produce the best results?
John Dillingham
06-11-2004 17:42:13
 Re: Correct gears for M.F. work. in reply to David Layne, 06-26-2002 16:42:10
I'm trying find a belt for a Big Bee 72. Can you tell me who is the manufacturer? or maybe the part number for the belt...
Ron
08-26-2003 07:35:53
I have a Massey 231S I mow in 1 High or 4 Low if the grass is damp. 1 high will yeild 2 acres per hour. Anything faster does not produce satisfactory results.
john
08-13-2002 23:25:16
please can you help I have a massey 35 3cyl deisel and under the fuel tank nearest to the dash board there is a 3 way brass fuel pipe connector, the top pipe coming out is loose even when fully tightened and leaks. any suggestions on how to remedy this, is something missing inside this connector. thanks in antisipation. Jophn
garvas
06-28-2002 11:21:15
I mow with a 60 inch brush hog using a 35 and usually will use 1st high and sometimes 2nd high. Depends on the height of the grass.
bob
06-26-2002 21:53:22
MF 65 manual calls for 2nd gear, high range for those kind of implements
Boss Hog
06-27-2002 10:19:16
 Re: Re: Correct gears for M.F. work. in reply to bob, 06-26-2002 21:53:22
Second gear in high range will really be flying if you have the engine wound up to PTO RPMs. I doubt it would do a decent job at that speed. Would be hard to stay in the seat on rough ground.
I think it's more trial and error, and depends on the conditions. Play around with different gears and see what works. I generally mow in 3rd low, and play with the multi-power depending on how heavy the stuff is.
