Fan belt help on MS50E
Don Mack
06-23-2002 07:49:31
I have vebration on the alternator which keeps braking the tension arm. The pullys look OK and run true so I think I need to replace the fan belt. But the hydo pump has a shaft connected to the front of the crank/pully. Do I have to remove the pump (shaft plate 4 bolts, pump 2 bolts & steel hydo flud lines) AND do I have to remove the fan blade and/or fan shroud ??
Thank for any help Don
marlowe
06-23-2002 09:13:39
 Re: Fan belt help on MS50E in reply to Don Mack, 06-23-2002 07:49:31
your on the right path pull the pump forward just to get the belt in. you don't have to remove the the fan or shroud unless you can't get at the punp bolts can't recall how much room you got
