Ferguson FE35 Main bearing kit undersize 060
Geert Beyaert
06-22-2002 23:51:16
I have a 4 cilinder fe35 ferguson 1957. the crankshaft is damaged at cilinder 2. the bearings were already undersize 060". As they told me this is the maximum. 3 questions.
Does somebody has experience with damaged crankschafts?(it is not a serious damage, it should only has to be taken off for a few more thousands of an inch)
Does sombody know where i can find main bearings undersize >060"?
Does sombody know where i can find a not expensive new or second hand crankshaft?
thanks.
marlowe
06-23-2002 09:23:45
 Re: Ferguson FE35 Main bearing kit undersize 060 in reply to Geert Beyaert, 06-22-2002 23:51:16
a good crank shop should be able to weld it up and turn it down to the original size. 60 is way to far per. the book 30 is most that it showes but then my book might not be right. i would leary of 60 on a engine that works hard. just my thoughs
