TO35 Deluxe Hyd parts
Jer
06-22-2002 19:44:34
I have just aquired a TO35 Deluxe and am having problems with the lift. While it is functioning it just cannot lift heavier implements. I assume this is a pump or lift piston problem. The question I have is more about parts to repair this. All the searches on the webI have done show parts for tractors with S/N > 174000. While the S/N plate is missing from this tractor, I assume it is about 145000 made in about 1955. THis is based on the engine block S/N of z135A600 and the green base paint on the engine.
Can anyone help with information on part sources for an older tractor like this? Any information on better identifying the model year would help also.
Thanks for your help.
Mickey Cook
07-15-2002 17:55:49
 Re: TO35 Deluxe Hyd parts in reply to Jer, 06-22-2002 19:44:34
Contact me if you havn't solved your problem yet.
Mickey
Tom Dold
06-22-2002 20:22:37
Jer
I Have some NOS parts for the hydraulic lift pump for the TO 35 prior to serial # 179340.
Tom Dold
Dold Implement Co. 605-772-4541
