MF 39 Corn Planter
Jay
06-22-2002 19:28:46
I have a #39 2 row corn planter, (#78 is the 4 row model). I have been checking with my dealer looking for seed plates that will work with Pumpkins. The ones I use for corn seem to chop almost 1/2 of the seed planted in two before dropping them because the cells are too small. The plates from the dealer are listed by size all of which are too small in my opinion. Does anyone either have extra plates hanging around, or a recomendation as to which plates will work correctly on pumpkins. I still use it for corn also so I don't want to mess with my only set. They do list a soybean plate. I understand the drop rate may be incorrect, but that one doesn't have a size listed for it. Would the bean plate have larger cells? I have never seen soybean seed. Thanks for your help.
Jay
Harry char
06-01-2006 07:01:41
 Re: MF 39 Corn Planter in reply to Jay, 06-22-2002 19:28:46
I have a # 39 MF planter. Do you know where to purchase corn plates for it?
Also, can you tell me what the hole diamenter in your corn plate is, and the thickness of the plate as I have access to some plates that have too small holes for corn,but can be motified.
Thanks,
Harry
Andy Wooten
04-30-2003 13:13:43
I too have the same m39 planter and want to plant pumpkins. There was a blank undrilled plate available in the past, but my local dealer couldn't find any more and the manual is out of print. Mine has a teflon plate with about 6-3/8" holes in it. If I had extra plates would try blanking off all but one hole and opening up the one left. Pumpkins need to be 3 seeds 3'apart. if you figure something out then please let me know.
Damon
06-24-2002 21:21:50
Jay,
while I do not have any experience with the planter that you own I can tell you that soybean seed is still quite a lot smaller than pumpkin seed. It would be slightly rounder/wider than corn but the length is similar.
Sorry I can be of more help.
Damon
Jay
06-25-2002 12:12:06
 Re: Re: MF 39 Corn Planter in reply to Damon, 06-24-2002 21:21:50
Thank you for your input. I guess I'm going to have to special order something close and modify it from there. Thank you all for your help. Of coarse, if someone has an old planter for parts or some older plates hanging around, please email me. I would love to have the oppertunity to purchase them. Thanks again.
[email protected]
