MF 50 dies after warming up
digiterrry
06-21-2002 08:11:52
My MF 50 dies a sudden death after running for about 15 minutes. There is no spark at the plugs, no spark at the points, and the points are opening ok. It will crank just fine but not start. An hour later it is good for another 15 minutes!? What ignition part could be causing this? Thanks for any assistance, folks!
Kelly
06-24-2002 10:23:31
 Re: MF 50 dies after warming up in reply to digiterrry, 06-21-2002 08:11:52
Your coil is probably heating up. Either it's bad or your condensor is about shot.
Don
06-23-2002 13:33:56
I thought all MF 50s were desial desiel desale . . you know, not gas.
Spelling Police
06-25-2002 10:45:27
 Re: Re: MF 50 dies after warming up in reply to Don , 06-23-2002 13:33:56
Diesel
bob
06-21-2002 20:29:54
Could be wire coming up thru distributer, worn thru and moving around, shorting out & killing it. Try moving dist. wire around right after it dies, see if it starts.
LH
06-21-2002 08:45:29
Sounds like either a coil or condensor. I'd try the condensor first since they're cheap.
