Ferguson tef
Richard Bertram
06-21-2002 04:51:39
would a perkins p3ta engine bolt straight in to the tef
Don
06-22-2002 05:32:48
 Re: ferguson tef in reply to Richard Bertram, 06-21-2002 04:51:39
P3s (ferguson conversion kits) were usually fitted to TEA & TEDs. The starter motor on the TEF diesel is on the wrong side and consequently the bell housing is slightly different. Depending on the flywheel housing plate, it might be possible to simply reverse it, but if the flywheel housing is an integral cast design, this obviously wont be possible. My Dexta uses the basically the same engine. One type has no flywheel housing and uses a fabricated plate to connect engine to the bell housing, the other has an integral cast housing. Interestingly the dexta perkins 3,144 engine with the fabricated plate has the starter motor on the correct side for a TEF, since modern Bell housings are to Standard SAE types, and the dexta engine is a p3 derivative,(as is the 3,152 of MF 35 fame) it maybe possible to carry out the conversion.
Don
06-22-2002 05:31:19
P3s (ferguson conversion kits) were usually fitted to TEA & TEDs. The starter motor on the TEF diesel is on the wrong side and consequently the bell housing is slightly different. Depending on the flywheel housing plate, it might be possible to simply reverse it, but if the flywheel housing is an integral cast design, this obviously wont be possible. My Dexta uses the basically the same engine. One type has no flywheel housing and uses a fabricated plate to connect engine to the bell housing, the other has an integral cast plate. Interestingly the dexta perkins 3,144 engine with the fabricated plate has the starter motor on the correct side for a TEF, since modern Bell housings are to Standard SAE types, and the dexta engine is a p3 derivative,(as is the 3,152 of MF 35 fame) it maybe possible to carry out the conversion.
