Oil pressure two high!!!!
Daniel Coates
01-15-2000 14:00:41
I know you have had messages about the pressure being two low, but i think mine is to high, the engine was worn out before and it was on high, and now the engine is done up it is still on high i have re-newed the pistons, liners, rings, valves, valve guides, it could just be the gauge but i was wondering if it was really a problem?
And any one know where i can find some nice cheap seconhand/new bonnet spares? in the uk?
Many Thanks
Daniel Coates
B.C.
01-16-2000 19:49:06
 Re: Oil pressure two high!!!! in reply to Daniel Coates, 01-15-2000 14:00:41
The quick way to check is to replace the oil pressure gage. They do go bad on occaision.
If that's not it, then maybe the oil pressure relief is stuck.
You don't say what engine that you have. On the gas Z134 it's inside the oil pump housing, which is below #1 main bearing. After the oil pan is off one can remove the oil pump and get to it.
On mine, somebody had shimmed the spring with a lockwasher for some reason. I seem to recall a fresh spring came with the pump rebuild kit.
Been fine ever since. Good luck.
Gerald J.
01-15-2000 17:49:25
Somewhere in the oil system there's a pressure control valve. Its stuck. It relieves excess pressure, probably through the oil filter. Or it could be the gauge.
The pressure control valve is usually a piston and a spring.
Gerald J.
