Massey ferguson 35
Gary Shortslef
06-19-2002 18:58:42
I'm haveing trouble with my neutal switch have put a new switch in but still haveing trouble staring it Thank you Gary
Peter, U.K.
06-20-2002 00:59:48
 Re: massey ferguson 35 in reply to Gary Shortslef , 06-19-2002 18:58:42
Gary, I had the same trouble with the neutral safety switch on my MF 65. You will find that the end of the shifter rail which pushes up the plunger on the switch is worn. There are three ways to cure it - 1. Replace the shifter rail with a new one , 2, bypass the switch by joining the two wires together, (not recommended) or 3, as I did, make an adapter for the switch. This screws into the hole that the switch fits into, and has a short vertical plunger in it's centre. The switch then fits into the top of the adapter and is held in place with a horizontal grub screw It's a matter of trial and error getting the height of the switch right but the adapter works perfectly now. Basically all you are doing is extending the length of the switch plunger. I hope you will understand what I'm trying to say, It's hard to explain but if you saw the adapter you'd know what I mean. If you need anymore help just e-mail me.
Regards,
Peter.
