Hi Marty - Any crunching noises? If so, don't run it again until you can get some expert help. Crunching noises are chewing up $100 bills. $50 for a service call is worthwhile at this point! No crunching - Does the PTO shaft turn with the PTO lever engaged? That will tell you if PTO drive train is working, if it is the conventional dual clutch setup. (If it's an independent PTO, I don't know the setup.) If the PTO turns, the hydraulic lift pump should be turning, and you have a leakage problem. PTO not turning? Possible clutch problem. Remove the plate under the bell housing (4 cap screws, about 1" heads), and take a look up inside. The driving gear train is separate. Remove the transmission oil filler cover and see if any of the gears are turning when the motor is running. Shut down and see if the gears are sliding when you move the 1-2-3-(4?)-R lever. Yes? then the problem is further back. Coupling to the differential is disconnected, or possibly High/low gears not engaging (loose shifter forks) or stripped. No? Possibly the clutch has a problem. Post some more info, and/or drop me a note - [email protected]
