Head on TO-20
Tom
01-15-2000 08:51:49
I have been slowly restoring a TO-20. It has a Contenintal 4 cyclinder. I have problems with the head sealing. I have had the head planed, new guides, and touched up the seats. It runs nice but there is a leak in the rear of the head. This is the 3rd time I have the head off. I discovered a small crack close to the rear stud. These are the short studs on the left side of the block. No doubt this has a factor in the sealing. However another problem I have is the new nuts for the studs I got, they seem to be too soft. (I got them from a Massey dealer). In other words, they tend to strip if I torgue them over 60 pounds. The manual states that the head should be torgued to 70-75 lbs. I replaced all of the studs and bolts. Maybe they gave me the wrong nuts. Is there a special sequence in tighting the head down? I start in the center and work my way to the ends. In the center of the block on both ends is a water jacket hole. The front one is blocked (don't know if it should be) and the rear one is open. The rear is where the leak is. I will have to replace the head or find someone who can weld it. But, I can't figure out why the bolts tend to strip over 60 lbs of torque. Has anyone had this problem or can someone steer me in the right direction?
