MF 135 Clutch not working
Cosmos
06-08-2002 17:19:46
Our MF 135 clutch is not working after having sat in the shed all winter. Worked going in, but coming out, we can't shift out of gear unless we turn off the motor to keep the gears from grinding. Any ideas on how to fix this issue? I notice there is a metal plate under the gear housing held on by four bolts, is there an adujustment to check?
Thanks for any helpful
shoe
06-10-2002 22:40:51
 Re: MF 135 Clutch not working in reply to Cosmos, 06-08-2002 17:19:46
Sounds as if the clutch plate has rusted or seized
to the flywheel. This is a common occurance with Masseys. Sometimes they can be freed buy hooking
the tractor to something solid and pulling against
it in a high gear. Quite often the tractor has to be split in order fix the problem. Good luck.
David Berger
06-10-2002 19:23:29
do any of you guys know how to fix multipower on a 165,cause my dad was thinkin about gettin it fixed.last time we got it fixed it cost 800 and broke the first time they went out in the fields.thanks for any help guys.
[email protected]
Booger Bob
06-10-2002 12:38:17
You might also get it loose by putting it in high gear, have someone sit on the tractor and hold the clutch pedal down, then rock the tractor back and forth.
kjm
06-10-2002 08:54:33
you need to put a load on it (log chain around a tree will work)put it in high gear with the clutch pedal down and pull. It will free up in 10sec. The clutch plate has rusted to the flywheel.
kjm
06-10-2002 08:53:28
kjm
06-10-2002 08:51:33
smokey
06-08-2002 23:21:42
Someone else had this problem recently. Some one else suggested removing the bottom insapection hatch - spraying with WD40 etc and leaving the clutch depressed overnight using a clamp etc.
Similar to what I do if my car has the same problem.
Phil in UK
06-10-2002 04:57:06
 Re: Re: MF 135 Clutch not working in reply to smokey, 06-08-2002 23:21:42
Most likely that the Driven plate has stuck to the flywheel. Can be caused by a little rust or oil. One way to release it is to put the tractor in first gear and start the engine (Make sure you have planty of room in front). Once the tractor is moving along gently press the brakes until the clutch releases. The clutch should be fine again until you let it sit for a long time.
Cheers
Phil in UK
06-10-2002 05:37:12
 Re: Re: Re: MF 135 Clutch not working in reply to Phil in UK, 06-10-2002 04:57:06
Sorry forgot to say that you have to have your foot on clutch when you apply the brakes.
