MF 135 Clutch just quit working!
Cosmos
06-08-2002 17:12:57
The clutch was working when I parked the tractor in the shed for the winter! Two days ago, I replaced the plugs, points, distributor cap, rotor, and condensor, fired up the machine, put down the clutch pedal, slipped into reverse/low and was surprised to find that depressing the clutch pedal did not release the gear. Since then, I changed the oil and air filters, started the tractor back up and let it warm up, hoping the clutch might just be stuck and needing release. Sadly, it is still not functioning properly! Does anyone out there know what must be done to get it working again? Is there anything to be done without breaking the t
Chris Brown
06-09-2002 16:42:08
 Re: MF 135 Clutch just quit working! in reply to Cosmos, 06-08-2002 17:12:57
try blocking down the clutch pedal for a day or two
Bob
06-09-2002 23:32:27
 Re: Re: MF 135 Clutch just quit working! in reply to Chris Brown, 06-09-2002 16:42:08
For really helpful information on how to fix the clutch see Jeck Wetmore's artical (left hand side of the screen under articles, then Maintenance, then MF35 (and up) Tractor Assembly Notes.
Also see Big Dean's web site.
I found both invaluabe when I had to try clutch adjustment then clutch replacement on my MF35X
