MF 35 stuck in neutral
Niley
06-06-2002 17:29:29
for the life of me I cant shift into any gear. I've taken off the filler cap and tried moving the selector fork with a screwdriver, but it wont budge, any suggestions would be appreciated.
PS. I have a 4 cyclinder 35, and I know the 3 cyclinder is a 35X, does the 4 cyclinder have a different letter after it? The label along the side was too faded out for me to see before i restored it.
Fred OH
06-07-2002 06:50:36
 Re: MF 35 stuck in neutral in reply to Niley, 06-06-2002 17:29:29
Did you try rocking it back and forth as you tried to slide the gears? Sometimes taking the pressure off will help. Or jacking up a rear wheel and rocking it. If you did this and still no help, chances are you're working on the wrong sliding gear. Try another. I found that mine went crazy when shifting from third to reverse too fast. Solution; slow down when shifting gears L8R....Fred OH
