Sure seal on 135
reed
06-01-2002 12:16:34
Does anyone know of the sure seal way of fixing a leaking rear axle will work on a 135? Most of the posts are regarding TO-20. Mine are leaking and sounds like a better method.
thanks
smokey
06-01-2002 17:06:52
 Re: sure seal on 135 in reply to reed, 06-01-2002 12:16:34
I think the only way is to remove the rear axle, press off bearings and replace seal. Reseting the shims in the trumpet housing is also required.
reed
06-01-2002 18:54:05
 Re: Re: sure seal on 135 in reply to smokey, 06-01-2002 17:06:52
Thanks for the reply. I was hoping to get around having to do that. Big Dean sent me a reply indicating that on the 135 replacing the inner seal (the one easy to get to) should be all that's needed. I think I'll give it a whirl and see what happens. The hard to-get-to seal is mainly for sealing the grease in the bearings.
reed
