FE-35 Front Wheel Alignment
Craig in NZ
05-31-2002 22:19:42
Hi team,
OK - as you may have gathered from my previous postings the front wheels on my FE-35 are not aligned properly. When one is pointing straight ahead the other one is pointing slightly in towards the straight ahead one - as if starting to turn a corner!. As Roger has advised there is some adjustment in the long shafts which run to the steering arms. I had a crack today at adjusting them by loosening the nuts at each end of the steering link rods. I then tried to rotate the rods (I assume they are on a thread?) to lengthen or shorten the link as necessary but they would not turn. Should I be using any tool for this turning or should man-power be enough? Any help gratefully accepted. Thanks Craig.
Roger
06-03-2002 07:20:06
 Re: FE-35 Front Wheel Alignment in reply to Craig in NZ, 05-31-2002 22:19:42
Craig;
Yes, the rods are threaded at each end. You
should be able to see the male threads of the tie
rod ends (the right angle assembly with the grease
fitting) entering the rod. You may have to use
Vise Grips, slip-joint pliers, or ? to get the rod
to start turning. Penetrating oil would make it
easier, too.
Good luck!
Roger
