MF-50 water leak
Marty Austra
05-30-2002 01:07:27
I have water leaking out a little hole in the side of my water pump!
Is this a major problem or somthing I might be able to fix myself .
ray-s
06-02-2002 13:48:04
 Re: MF-50 water leak in reply to Marty Australia, 05-30-2002 01:07:27
>Link
>Link Water Pump - Pump with pulley, for A3-152 diesel in tractors: MF35, MF50; ind 35, 203, 205. part No: 742558M91) $81.00
Marty, the above lnk? is from this forum. This is for a MF50 . Have you checked with BARECO in OZ? ray-s
Bill in TN
05-30-2002 06:05:20
If your an average or fair mechanic you can do it....if you have problems with fractions...and don't know a 1/2 from a 9/16.....you might want to get some help.....I would not be afraid to attempt the repair, but I have a full time job and my tractor doesn't need to run every day....my guess would be 4 hours from start to tools put away and hands washed....pro's probably faster, you could check a flat rate manual for average pro's time....but most can usually do it in half the time of the flat rate manual..... I say.....GO FOR IT!!!!!
Marty Australia
05-30-2002 07:23:58
 Re: Re: MF-50 water leak in reply to Bill in TN, 05-30-2002 06:05:20
Thanks for the advice Bill
I decided to have a better look where the water was coming from and ended up taking the water pump off. I'm glad I did, the bearing in the pump is stuffed and which I supose killed the seal. With a bit of luck I hope to find a replacement pump or some sort of kit .
The nearest Perkins dealer to me could not even figure out what type of engine I had last time I went there.
Cheers Marty in oz
Bill in TN
05-30-2002 12:07:57
 Re: Re: Re: MF-50 water leak in reply to Marty Australia, 05-30-2002 07:23:58
Not a problem.....hope you find one...I suppose if you can't find one there, I,or one of us could ship you one....not sure about those plastic ten dollar bills though....Bill in TN
