Stuck valves
Frank B Aldous
05-27-2002 17:23:17
I have a massy harris 30 with four valves that are stuck. What is the easiest way to ge them loose.
Chris Brown
05-27-2002 18:48:33
 Re: stuck valves in reply to Frank B Aldous, 05-27-2002 17:23:17
DYNAMITE, no, not really.just soak it good,I'd use diesel and ATF mix for a couple days in the plug holes ,then pull the valve cover and gently pull up on the valve cap not the spring with two screwdrivers and tap lightly down the valve over and over.everybody has their own all time best solution of mixture to soak it in,I just use whatevers cheap and handy,diesel and tranny fluid. If you pull the valve train off you can jerry rig a spring compressor usually from a piece of flat steel with a hole, with the piston up remove the valve spring and use an electric drill on the valve stem and an oilcan till everything is nice and loose..good luck
