MF 165 Gas Overheating?
Doug Decker
05-26-2002 21:00:50
My 165 Gas is cutting off after I bushhog for about 20 minutes. Acts like it is fuel starved, I can keep it running a little if I pull out the choke but it will shutoff. I can restart it right away but it only runs slow and then will cut of again. I thought I had a problem with sediment in the fuel tank but it only cuts off when the temperature needle goes slightly past the operate dot. Tractor runs great for first 20 minutes. Appreciate any advice you can give me.
Don
05-27-2002 07:35:49
 Re: MF 165 Gas Overheating? in reply to Doug Decker, 05-26-2002 21:00:50
Sounds like the carb could use a little adjustment. I beleive it is the bottom screw on the carb that controls how it runs at high rpm's. I'm not sure what way to turn it, but after playing with mine once when it was running rough after it got warm it ran fine ever since.
Don
