Head bolts
jim cantrell
05-25-2002 18:47:48
i need to know the torque specks on a fe-35 with a 23c for the head bolts, thanks
Jack in NB
05-26-2002 03:00:38
 Re: head bolts in reply to jim cantrell, 05-25-2002 18:47:48
Hi Jim -
The I&T manual states 100 to 105 ft-lbs, moving from the center outward.
I clean the threads on the cap screws and if they don't screw into the block freely run a tap into the threads in the block, then blow out the crud. (Cover the pistons and camshaft!) After the head is on, I oil the threads lightly and bring them up to full tourque in 25 or 30 lb steps.
A bit of extra work, but I haven't had failures.
The book mentions copper side of the gasket to the block, and also that it is marked "top". I don't recall that from my last overhaul. They don't mention using a gasket shellac.
jim cantrell
05-26-2002 07:41:34
 Re: Re: head bolts in reply to Jack in NB, 05-26-2002 03:00:38
thanks jack, i recently changed head gasket and now it is leaking again. i'm not sure but i think i put the copper side up toward the head or both sides had the copper on them ( my memory is going fast)where can find a manual for it i can't find it around here? i'm lucky just to find parts.
